Cam Clearance question
Old Apr 3, 2006 | 12:02 PM
Steve B's Avatar
brings his heater.
Default Cam Clearance question
Stock bottom end.
B-303 with 1.7's. heads have 2.02 intakes.
if you have run this combo please let me know if they hit or not.
Old Apr 3, 2006 | 12:31 PM
Steve B's Avatar
brings his heater.
Originally Posted by Scott
I had a F-303 with 1.72 and no issues. Can not remember the specs right now but maybe that will help a little.
Try the Ford Motorsport Tech line: 1-810-852-9347
were those with 2.02 valves?
Old Apr 3, 2006 | 02:24 PM
Drewpw4ng's Avatar
stock :-\
2.02 should most likely fit. the total lift and duration of a B cam+ 1.72's shouldnt be much more then the F cam on 1.6s
Old Apr 3, 2006 | 05:14 PM
Civickid5835's Avatar
We are running a F-303 Cam with 1.6 roller rockers. And we dont have any clearnance problems. We spoke with Ford Motorsport last year and they said that we can run the 1.7 rockers without a clearance problem. If you step up to the X-303 Cam then you will definetely have to be careful and check your clearances
Old Apr 3, 2006 | 05:46 PM
shinysideup's Avatar
TR Balla Donor Supreme
Always use the putty test. Especially when in doubt.
Old Apr 3, 2006 | 06:19 PM
herrcomestrouble's Avatar
+1 on play dough.... Is it stock block, stock heads? Or have they been mahcined? You shouldnt have any problems, but its always better to check...
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Apr 3, 2006 | 06:25 PM
$hawn's Avatar
lives in a glass house
don't think it's a cam and rocker issue, It's the 2.02 valve.
Steve I don't *think the 2.02 will clear it.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Apr 3, 2006 | 06:30 PM
Drewpw4ng's Avatar
stock :-\
trickflow wedge heads have 2.02 valves dont they? they bolt right on to a stock shortblock with a .499/.512 224 duration cam, as a package... i think the 2.02s will work out, just playdo it
