Head, cam, bottom combo?
Old Mar 31, 2006 | 08:15 AM
TampaMille's Avatar
Resident Ham-N-Egger
Default Head, cam, bottom combo?
Thinking of running an F-cam (I now have an E-cam) and AFR 185 heads on a stock bottom end. Any advice, experience or warnings on this combo? Dangers of valve to piston clearance, good combo, bad combo, etc. Thanks in advance.
Old Mar 31, 2006 | 08:37 AM
Flastangs's Avatar
I run a F-cam with Dart heads and 1.6 RR with no problems. Car sounds good too. My car has stock bottom end.
Old Mar 31, 2006 | 11:28 AM
evocrazy1's Avatar
i run a F-cam 1.7 rockers, and TEA ported TFS track heat heads. Sound like a good combo that has the potential to make good usable street HP.
ASKED TO BE BANNED
Old Mar 31, 2006 | 11:34 AM
OldMan's Avatar
Donut Killer
The springs that come on AFR185s are good for up to .550 max lift. and have 2.020 values.
E303 - .498 max lift with 1.6 rockers,
F303 - .512 max lift with 1.6 rockers,
F303 - .544 max lift with 1.7 rockers, (.512/1.6=.32x1.7=.544)
1.6, you should be good.
1.7s will work for the springs. As far as clearance, guess everyone else has already covered that.
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
Old Mar 31, 2006 | 02:24 PM
Drewpw4ng's Avatar
stock :-\
u need to notch the pistons, AFR 185s valves are too big.. 165 with an F cam would work fine
Old Mar 31, 2006 | 02:27 PM
TheShow50h's Avatar
The little 5.0 that could
2.02 valves will be pushing it with a stock bottum end and an f cam... 1.94 valves will definately work though.
-Vince
Old Apr 3, 2006 | 07:46 AM
TampaMille's Avatar
Cool! Thanks all. I was hoping not to notch.
