ignition problem?
Old Mar 18, 2006 | 08:18 AM
Hybrid_Ej1's Avatar
5th ej1 one in the making
Default ignition problem?
my boy has a 88 mustang gt and he has a problem. the car starts just fine and runs fine too, but when he turns it off and takes the key out the car still runs and you have to disconect shit to cut it off. this just recently started happening. he already bought and installed a new starter, starter solenoid, and ignition lock cylinder. anyone know what it could be? lmk asap
EJ Crew Member #2
Old Mar 18, 2006 | 08:38 AM
Hybrid_Ej1's Avatar
he replace the whole part where the key goes in what ever that is called. what else could it be?
EJ Crew Member #2
Old Mar 18, 2006 | 10:26 AM
Hybrid_Ej1's Avatar
anyone?
EJ Crew Member #2
Old Mar 18, 2006 | 11:04 AM
JDL1000's Avatar
The part your key goes into has nothing to do with the problem. You need to replace the actual ignition switch. This is a pic of the ignition switch. It's most likely your problem. You can get one anywhere I think their only around 20.00 at Ford.
Life moves pretty fast. If you don't stop and look around once in awhile, you could miss it.
-- Ferris Bueller --
Old Mar 19, 2006 | 06:42 AM
Mr Goats's Avatar
it may not be the igition switch.
here are some of the top causes idle speed to high
ignition timing incorrect
incorrect spark plug heat rang
vacuum leak at the intake manifold
carbon buildup in combustion chambers
vavles leaking
Old Mar 20, 2006 | 04:47 PM
JDL1000's Avatar
vavles leaking
Your talking about (Engine run-on, Dieseling)
I think this guys car just continues to run like he never shut it off.
Old Mar 20, 2006 | 06:48 PM
JDL1000's Avatar
Originally Posted by Mars_302
it takes a lot though for a modern SEFI motor to do dieseling
Same as I was thinking...
