Spec Cluthes??????
Spec Cluthes??????
Anyone Know Anything About These Spec Clutch Kits?? I've Seen Them Around But Havent Heard Anything Good Or Bad About Them. If Anyone Has Input (good Or Bad) Please Let Me Know I Found The Stage 1 Kit For 179.00 Like To Get It Asap.
Also What Would Alow A Clutch Fork To Be Able To Move Up And Down About An Inch Each Way??? Mine Can And I've Never Seen This Before Plus It Makes A Hellova Racket At A Stop Light, Kinda Like A Sliping Belt.(hense The Question On The New Clutch)
Bad throwout?
Originally Posted by Duceanahalf
Bad throwout?
I swapped out my Spec stage III after 10K because the throw out bearing blew apart.
10 SS/RS
06 Busa
10 SS/RS
06 Busa
BUT HOW MUCH POWER ARE YOU RUNNING???? I'M NOT PUSHING THAT MUCH, JUST A FOX BODY WITH A 306 AND SOME WORK, THE STAGE 1 SAYS ITS RATED AT 400 FTLBS. I DONT THINK I'LL EVER GET THIS CAR THERE!!!!
Ive got a stage 2 in mine. Some use a stage 3 if they go to the track mostly. Dont use the throw out bearing spec supplies (plastic). I didnt know that when I put the car together but its running fine. Use the Ford T/O (metal) and you should be fine. A stage one might be good for a V6 but if you putting any power down step up to a stage 2+. Good Luck.
-Ryan-
-Ryan-
