Too Hot!
Old Mar 10, 2006 | 03:58 AM
S281-335's Avatar
Exclamation Too Hot!
I want to lower the temp the electric fan comes on in my 96. I understand it comes on at 220. I'ld like it around 185-190. I just put in a Fluidine radiator and a 180 stat, new hoses and waterpump. it runs cooler than it did, espicially when the ac or defroster is on.(cause the fan is on.) but without the AC,the gauge climbs up higher than i would like before the fan cuts in. Is there a different sensor for the fan switch with a lower temp range I could put in or maybe and adjustable one even? I'm sure there is a simple fix for this I cant be the only guy wanting to do this. HELP!!!
Old Mar 10, 2006 | 01:11 PM
figment's Avatar
Jonathon
you need a programmer or a chip burned, ive done mine with my predator.
SOME PEOPLE ARE ALIVE SIMPLY BECAUSE IT IS ILLEGAL TO KILL THEM
Old Mar 12, 2006 | 04:33 PM
trey's Avatar
wo0t
either just hot wird ur fans to a switch or just put ina 160 stat and u should have any problems
Old Mar 12, 2006 | 04:51 PM
ODB's Avatar
ODB
S.Y.L.O.
http://www.allfordmustangs.com/Detailed/499.shtml
this is the right way to do it...I did my 95 cobra this way....puts my mind at ease in traffic
Old Mar 12, 2006 | 04:58 PM
herrcomestrouble's Avatar
+1 on that extra switch Pat. I had a ECT sensor shit the bed, and ended up costing me a headjob ( the bad kind ) The ECT went out, fan never came on, by time i pulled over it was HOT, and i shut the engine off... it was 2 late... warped heads, new headgaskets, yada yada...
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Mar 12, 2006 | 05:00 PM
ODB's Avatar
ODB
S.Y.L.O.
werd up cody...basically you are bringing one wire to ground with the switch.very simple..
nice car mang!
Old Mar 13, 2006 | 09:41 AM
pinellas50's Avatar
You could also take the fan operation completely away from the computer all together. Then put in a fan controller like the DCController FK35.
www.dccontrol.com
