Vibration at 4k
Old Mar 9, 2006 | 12:56 PM
SGear's Avatar
two hairy fl palms
Unhappy Vibration at 4k
I had a wicked vibration before replacing the harmonic balancer, now all that has gone away except at the 4,000 RPM mark and it doesn't matter what gear I'm in. Only at 4k it vibrates, when rpms increase or decrease away from 4k it goes away.
....anyone know what's up ?
Don't you wish there were a knob on the TV to turn up the intelligence?! There's one marked 'Brightness' but it doesn't work.
www.cnhosts.net
www.bangstang.net
Old Mar 9, 2006 | 01:36 PM
cochese's Avatar
Chucking up the Dueces
drive shaft may be out of balence
Induction Performance.com
PTC torque converter
Aerospace Components
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
Old Mar 9, 2006 | 01:55 PM
FoxBodyBlur's Avatar
Insert fancy title here.
might be motor mounts. but idk why it would only be at a certain rpm tho
Old Mar 9, 2006 | 02:04 PM
ODB's Avatar
ODB
S.Y.L.O.
+1
Old Mar 9, 2006 | 03:26 PM
does the motor rock a lot when u go to start it?
Old Mar 9, 2006 | 05:43 PM
SGear's Avatar
two hairy fl palms
I don't know but I will check that in the morning and let you know.
The motor mounts are in good shape, one is brand new the other is original.
www.cnhosts.net
www.bangstang.net
Old Mar 9, 2006 | 05:55 PM
if it's an original from 1990 u might need to replace it lol
Old Mar 9, 2006 | 06:50 PM
Strokd85's Avatar
Daddy-O
does it do it while in neutral?
I am your penalty.....
