Fuel pressure problem
Old Feb 23, 2006 | 09:14 PM
GTman85's Avatar
KBizzzle
Default Fuel pressure problem
SO i was at RaceRelated all day tuesday getting a partial tune for my wet kit. Only problem is im getting some sort of fuel pressure surge at WOT. On the motor and on the bottle. Cars fuel pressure will go up on accerlation but up top itll surge down 5 or 10 PSI. Car has a E303 cam, ported stock heads, and a supposed 255lph pump. At RR i had a faulty fuel noid so i replaced it. I replaced my fuel filter with a new one, all while i was there. I couldnt get under 14:1 A/F. It was lean as piss. I had the biggest flippin fuel jet in there and still was putting out a 14:1 or higher A/F. What were thinking is something to do with the fuel pump. Car has stock 19# injectors. Im completely mind boggled as to what it could be. The car does feel really sluggish up top. This weekend ill pull the tank and see if the sock on the pump is dirty. Also make sure its even a walboro pump. Any info would be great guys.
-kyle
^^Makes me warm and fuzzzzy
Old Feb 24, 2006 | 11:48 AM
GTman85's Avatar
KBizzzle
Anyone??
Old Feb 24, 2006 | 04:04 PM
Drewpw4ng's Avatar
stock :-\
bigger injectors? i was fine with 24#s
Old Feb 24, 2006 | 04:32 PM
GTman85's Avatar
KBizzzle
Its a wet kit. I didnt think 19# would be a prob. I thought the fuel pump would take the beating
Old Feb 24, 2006 | 04:55 PM
Drewpw4ng's Avatar
stock :-\
wouldnt hurt to throw in a brand new 255
Old Feb 24, 2006 | 08:36 PM
GTman85's Avatar
KBizzzle
the car was supposed to have one in it already. Im going to drop the tank and check the sock on it to see if its clogged up
Old Feb 25, 2006 | 04:00 AM
T/S #25's Avatar
Need To Get Quicker
A pressure drop usually means the pump isn't keeping up.
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Feb 25, 2006 | 06:07 AM
GTman85's Avatar
KBizzzle
ok will check. 2 days before the dyno i put a BBK AFPR on it
