mustang engine weight.
TR Registered Member #5
on
anyone have any idea what a 302 completely stock with a carb and t5 weighs? also, about how much does the aluminum heads drop off the car once you replace the iron ones?
http://www.floridaracing.org
not to bust balls here but stock with a carb? Aren't they fuel injection?
Maybe I don't know my shit afterall
on
well, if im not mistaken, the early generation 302s were carb.
but thats not what im getting at.
basically a fuel injected weight is fine, but i roughly need to know what pulling all the FI stuff off and going carb drops as far as weight goes.
ohhh got ya.... I have no idea... I would of looked it up on the internet but I doubt that is something you would find on there... Hmmmm dont know what to tell ya..
but if you trying to reduce weight for handling I heard that it was more important where it sits rather than try to get all the weight. Like if you moved it like 2 inches to the middle and like 2 inches lower. It would help A LOT more than just taking 100 lbs off.
that is what I heard
Originally Posted by evocrazy1
prolly like 20 lbs, and head raised the nose of my car about 1/2 inch
dang hahaha changing the heads raised your car that much
good stuff
aluminum heads are good for a 40lb reduction
Originally Posted by Scott
400-425 on a aluminum headed 302 with a carb and the t-5 is about 75-90 lbs. so about 500 total.
The FI stuff weighhed about 40 lbs since the upper on the 5.0's were so damn heavy.
Damn that means my motor/ trans weighs about 650lbs. if i did not need a motor i could be below 3000#s
Where the hell did i put that mountain of gold so i can build an all aluminum motor.
ASKED TO BE BANNED
ASKED TO BE BANNED
