FI to carb info needed
ok what all would i need the swap to and carb setup on my 89 5.0 i would also like to keep the stock gauges working and the a/c too is there a way to cut some wires out of my wiring harness to make the stock stuff work still and what parts will i need to buy i got a carb,intake,and fuel tank from my 85 gt what are some of the other things that will be needed.Thanks
2008 Acura TL DD
1998 Beater Ranger DD
1994 Ford Mustang Project
2008 Acura TL DD
You will need intake/carb/fuel pump and regulator/dist./coil/ignition (duraspark or msd)fuel line/in tank pick up (or modify the stock one) valve covers (or modify stock ones)/air cleaner. I think thats about it. I can show you how to wire up the a/c once you get the conversion done. Let me know if you need any help/tips.
i have a 85 gt can i just pull all the parts off it anf put them on my 89 and make the 89 carb that way
2008 Acura TL DD
2008 Acura TL DD
Guest
Posts: n/a
For the most part yes.
You will want to go to at least a Holley Blue pump and bigger fuel lines. Add a adjustable fuel pressure regulator, and a better intake manifold. The Edelbrock Performer RPM Air Gap is a nice piece.
The distributor should drop right in but if you change the cam make sure you have the correct distrib. gear to match the cam.
ok my 85 is now a 306 and its about 350 hp why would i need bigger fuel lines if the motor runs great in the 85 all i want is to put the motor and trans in the 89 and do a few more lil mods so is there a way to use all the stuff from my 85 and the reson for all this is the 85 is very rusted out and need alot of body work so for now that body will just sit.
2008 Acura TL DD
2008 Acura TL DD
Derp!
