Ford 8.8 questions
Old Feb 5, 2006 | 04:23 PM
Rotary7's Avatar
Get Down-Or-Stay Down
Default Ford 8.8 questions
I have a few questions im hoping you guys can give me some info on.
Im looking into the Ford 8.8,with disc brakes
I need it in a 4 lug and if possible the shortest width I can find it.
Would the Fox body mustang be a good place to start looking for one of these?
How much HP/TRQ are they good for?
Whats the average going price for one of these,brakes to brakes?
I just need a little info to help me find out if this is what I need.
Thanks
Do you want to be tazed?
Old Feb 5, 2006 | 04:33 PM
BigDawg's Avatar
has his prioritys ef'd up
You wont find a fox mustang with disk brakes unless its an SVO, or Saleen, or Cobra and the saleen unit is that same as the MK VII, however these are all 5 lug. You can also look for T bird Turbocoupe which had 4 lug, but was still wider than a fox 8.8 by 1.5" total. They can hold up o a decent amount of power depending if your using slicks, because those will cause axels to snap like a pretzel. And the average price is about 200.00 for a disk to disk rear end.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Feb 5, 2006 | 04:53 PM
Rotary7's Avatar
dam so they came with drums,
But did the fox bodies all have lsd?
Would if be easy to convert to disc?
Thanks for the info
Old Feb 5, 2006 | 05:15 PM
BigDawg's Avatar
to convert to rear disk is actually pretty simple, there are a few companies that make brackets and with some GM calipers from a Cadillac and some 4 lug or 5 lug rotors, you can get rear disk brakes, alot of the jeep guys do this, and its cheap and works pretty damn good. But most guys do the axle swaps, use a proportioning valve and get a different master cylinder, cuz you will need one from a 4 wheel disk car, if not you have some fugged up spongy brakes to work with, which I would not invest 10 cents into. But yeah , 99% of all stangs other than those listed above came with drum brakes. And what is lsd????
Ryan
Old Feb 5, 2006 | 05:22 PM
Duceanahalf's Avatar
is doing your girlfriend
I converted my Crown Vic to rear disc from rear drums. Using the original MC and Prop valve. Brakes seam to work fine, although they need to be bleed again. With the 10" front disc and the 11" rear disc, car will throw you into the belts pretty damn hard.
Old Feb 6, 2006 | 11:54 AM
Rotary7's Avatar
LSD=Limited Slip Differentual im pretty sure Ford calls it that.
GM calls it POSI
Heres what i was thinking on the disc brake set up.
Take off the drums/back plate etc etc..
Find a rotor with the same lug pattern.
Weld on the bracket to the rear end,with the caliper.You just got to make sure the spacing is the same.
Old Feb 6, 2006 | 12:19 PM
evocrazy1's Avatar
ford calls it a trac-loc, you can pic them up cheap, i get them from a MKVII for a $100 disc to disc
ASKED TO BE BANNED
Old Feb 8, 2006 | 04:06 PM
Rotary7's Avatar
Dave,
Can you measure from the farthest point (center disc to center di
So I can get an idea on how wide it is.
then I will compare it to my stock rear,the gearing dont matter I need high 4s
