Gear for a c4
Figure out what your final combination is going to be and how much power/torque you are going to make, and then you will be able to figure out what gear ratio is going to work best for you. What works good for you now won't be optimum when you finally get around to adding nitrous to the combination, and then you will end up changing to gear again.
