C-4 questions.
I ordered a PA Comp C-4. Ive never delt with one before and have a few questions. First it has a full manual valve body will i have to have a kick down cable? What about the vacuum modulators? will i have to hook them up top a vac source? And does any one have a big bellhousing for a case fill tranny?
Anyone?
Originally Posted by FBP
no kick down......it's all you.
Full Manual = You shift up and you shift down, any shifting done will be done by you. Dont forget that when you drive up to and come to a stop at a traffic light, when you take off, to put it back in first or you will start off in the last gear you were in. That can be a costly lesson if you learn that one the hard way.
Another question.
Can i use the VSS out of my AOD in the C-4? I slipped one in there today and it seamed like it would work. My VSS is a cable driven unit.
Originally Posted by shinysideup
what do you mean by "big bellhousing"?
Originally Posted by Duceanahalf
Another question.
this site sucks balls now. fuck tampa racing, not coming back.
There are two different bellhousings for teh C-4 one for a 157-tooth flywheel, and one for a 164-tooth flywheel. The 164 t bell is about 1" wider at the large end. The big bells pretty much only came on cars with the 351.
