Changing ball joints
Old Jan 20, 2006 | 05:41 PM
Whaazup17's Avatar
Default Changing ball joints
What tools do I need and what parts would I need?
-garrett
Old Jan 20, 2006 | 06:30 PM
Whaazup17's Avatar
ahh ok. What does the ball joint actually do? It is for my steering correct? Why would I need to remove my spring if it is for my steering?
Old Jan 21, 2006 | 05:59 AM
Whaazup17's Avatar
I just lifted the car and seen if there was play in the wheels. There might of been about .005" of play but I wouldn't think it was anything to worry about.
Old Jan 21, 2006 | 07:35 AM
$hawn's Avatar
lives in a glass house
the lower ball joint is just press fit. a 2lb sledge makes quick work of removal.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Jan 21, 2006 | 09:57 AM
Whaazup17's Avatar
I do'nt wnat to sound like an idiot or anything but where do I look for the ball joint? Is it on the threaded rod that connects to the steering rack?
-garrett
Old Jan 21, 2006 | 10:12 AM
$hawn's Avatar
the threaded rod you're talking about is a inner tie rod. The outer tie rod screws on to that and goes in to the spindle to steer the car.
Ball joints: Mustangs only have lower ball joints, it is what comes up though the lower control arm in to the bottom of the spindle. hope this helps...
Old Jan 21, 2006 | 10:15 AM
Whaazup17's Avatar
hmmmm ok... The tie rod goes on to a bolt with a castle nut with a cotter pin.
Is this the ball joint? Then I seen another one with some yellow grease hanging out on top which is higher than that one.
Old Jan 21, 2006 | 10:56 AM
$hawn's Avatar
hope this is better...
Old Jan 21, 2006 | 11:04 AM
Whaazup17's Avatar
ahhh ok I got to remove the spring now I understnad it... Got ya... Couldn't I just put a jack under that arm and lower it that way?
