blow through question
you can run a blow off valve. bypass is basically just for MAF equipped cars that need measured air kept in the system and not vented away (it causes a rich condition, since the computer has accounted for XXX amount of air and has added fuel accordingly then you go blow it off)
for a blow through, you can run a blow off to atmosphere. im a newbie to the carb world but i cant see any reason venting off what would be compressor surge/back pedal causing an issue as the air only really gets measured prior to going to the intake.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
