Backfire through the carb
Originally Posted by 69Boss521
It just started doing it, new cam and new valves. The spacer under the carb has been there since the rebuild. I will check my vaccum lines tomorrow.
It sounds like you need to re lash your valves. sounds like one is to tight
My 0.02
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
Could be timing 180 out if all else fails pull the distributor out make sure #1 cylinder is at tdc on the (compression) stroke.turn the motor over by hand with a ratchet or breaker bar until u feel air come out of the number 1 cylinder. that is the compression stroke then put the distributor back in with the rotor facing the number 1 plug wire.
