Does anyone know???
Old Dec 31, 2005 | 07:51 PM
RedEyesMach1's Avatar
Mach 1 speed
Default Does anyone know???
Where I can find a write up on going from a stock Sn95 5.0 to supercharged? I'm looking more along the lines of what has to be done to the motor like other mods before its ready for the supercharger.
Old Jan 1, 2006 | 06:21 PM
OldMan's Avatar
Donut Killer
Try doing a search on MM&FF or 5.0, there should be old tech articles.
For a quick note, you will need injectors or FMU, matching mass air if you upgrade injectors, timing module (i.e. MSD 6BTM) and new fuel pump. Plugs, wires, and coil wouldn't hurt either. This is also assuming that you do not try to stuff more than 8-9lbs of boost in there. If you want more, then you will have to go into the motor and heads to compensate for the additional boost. Otherwise, you won't be running long....
If you don't find something on line, I will try to dig through some old stuff to find an old write. But I am tired and need to get some sleep for now.
Also check.... http://superchargerhelp.com/
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
Old Jan 1, 2006 | 06:26 PM
Mach 1 speed
I appreciate the help. I searched around and found a great site for help on the Superchargers but I couldn't really find the info on the best mods to perform before the SC goes on.
Old Jan 2, 2006 | 06:12 PM
Eric@TBMustangs's Avatar
www.TBMustangs.com
That sounds about right to me. You might be able to find a complete kit for sale somewhere.
Eric Powell
Tampa Bay Mustangs
www.TBMustangs.com
Over 315 members and growing!
