Head Tech Input???
Currently on the 351w I have a set of 1969 HIGHLY ported and polished heads with 1.94 and 1.6 valves. I found a local set of Eddlebrock performer RPM heads for about 500 bucks. Are these heads worth the money and time to swap heads??? If not.... what heads do you guys recommend??? Will Trick Flow High Ports work and are they worth it?
351w
.60 over
Hydraulic .550 cam
Forged Ross flat top pistons
H beam rods
Forged Crank
775 CFM Race Demon RS carb
Eddlebrock Single plane - torker 2
351w
.60 over
Hydraulic .550 cam
H beam rods
Forged Crank
Derp!
Derp!
the rpm heads have 2.02 valves and they each weigh prolly 20 lbs less than the cast heads, so youre dropping 40 pounds right off the get, and for 500 bucks its like b.o.g.o
high ports are good too
-Ronald Reagan
-Ronald Reagan
What do the heads that you currently have on your engine flow?
