boosted ?
Guest
Posts: n/a
The stock blower has a sort of bypass valve that will bypass the blower at light load. This avoids stress on the blower and lowers inlet temps when not in boost.
I don't think anyone is putting a true blow-off or bypass valve since it would have to go after the blower and there isn't much room to do so.
On the centrifugals (Vortech, Paxton, Pro-charger, etc) blow-off's and bypass's are much more common than they used to be. Its a pretty good idea to run one.
I have one, it is supose to relieve pressure when you slam the throttle shut and the compressor is still spining.
John
John
John
1992 Mustang LX 5.0-Powerdyne BD-11A, 3.73's, FRPP clutch, chrome Ponies, Mac headers, Aeromotive regulator, MSD 6A, MSD BTM, FRPP 42# injectors, Pro-Flow Air Optimizer, Trick Flow Track Heat intake, Edelbrock 75MM TB, AFM Power Pipe
John
