help spend my money
Old Dec 1, 2005 | 07:46 PM
96fcobra's Avatar
Default help spend my money
i own a 96 ford cobra with 46000 miles on it. its pretty much stock with a few minor bolt on. im currently in iraq and just trying to figure out what i wanna do to the car when i return soon. i am looking at supercharging and further bolt on. any advice. also i dont really understand this stroker kit stuff. i see a kit to make a 4.6 in to a 5.0 302 or 306? can someone explain this to me and would it work im my cobra? thank you i can use the the help i can get
Old Dec 2, 2005 | 05:32 PM
Zman's Avatar
I gota Cheby
Dont know the 4.6 motor but supercharging yes. Definate yes. Either the Vortech S trim or maybe the Novi 1000 or 2000. I have the 2000 this will support 900 hp capable. Procharger makes a P1sc with intercooler. I've had all 3 at different times. (not the same car) Trying the Novi 2000 next for max power. By adjusting pulley size you can go mild to wild to where it might even split a block . I would try the Corral for more info on superchargers. Many debates on whether Nitrous, turbo or supercharger is better. They cover all the bases. Goodluck in Iraq and be safe and thankyou. Andel
Only 1/4 mile track I know is Gandy Bridge
Old Dec 2, 2005 | 08:10 PM
96fcobra's Avatar
yeah i really wanna do the supercharger. i see alot of them say i can bolt on to stock motor? how is this possible. there has to be some thing i have to do. wpi;dnt i destroy my motor?
Old Dec 2, 2005 | 08:19 PM
the anti-rice's Avatar
finally painted the car!
Like he said try www.corral.net and do a search on there. There is soo much info about S/C and stroker motors itll keep you busy for hours. You deff. want to put more fuel in the motor to accomodate (sp) for the S/C. Good luck and thanx for surving.
-Ryan-
Old Dec 2, 2005 | 09:49 PM
evocrazy1's Avatar
First of all thanks. My gf drives a bossted cobra everyday, she runs a Novi 2000 with a max bosst of 14lbs on her stock 98 cobra, its had a s/c on ever since she bought it which was 2 yrs ago, she has 50,000 on th ecar now, and she recently just upped the boost to 14lbs, i think it would last a while as long as the bosst was kept at a moderate 8 lbs, i love superchargers. love the whine from them
ASKED TO BE BANNED
Old Dec 4, 2005 | 02:50 AM
allibabba's Avatar
What if you saved your money, then sold the 96 and bought a 03-04 when you got back?
Old Dec 4, 2005 | 04:47 AM
SoL_93GT's Avatar
If you need to rebuild you motor then it would be a good time to make it a stroker otherwise you should just run the stock motor, it should take quite a bit of abuse before you need to upgrade anything in the shortblock. The stroker kit increases bore size and stroke to increase displacement. I'd go with an intercooled blower setup, having the lower air charge temp the less likely you'll have detonation problems and you'll be able to run more boost on pump gas with the intercooler. The Procharger kit comes with an intercooler. You could make 500 rwhp with the right tune on the stock motor with a blower and that would give you enough power to run mid to low 11's. You might need to upgrade your clutch at that time too, I don't think the stock clutch would last too long at that power level. And if you're going to put slicks on it you're gonna want to get 31 spline axles and while you're working on the rear, I'd put a set of 4.10 gears in it. Have fun.
Briane
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Old Dec 5, 2005 | 07:43 AM
.Seth.'s Avatar
TR Balla Donor Supreme
Keep the cobra n go w/ turbo or S/C, you see alot of s/c'd mustangs so I' prboely go turbo like a t4 set up or sumthing w/ FMIC
Old Dec 5, 2005 | 06:39 PM
96fcobra's Avatar
ive got 4.10s on there now so thats good, im looking around the wed now for s/c ot turbo. i guess my only question now is which one and with which company?
