Cant get the car to fire
Old Dec 1, 2005 | 08:25 AM
88stang5.0's Avatar
00 Yzf R1
Default Cant get the car to fire
Ok we have everything hooked up but we cant get the car to fire! we checked the box for all the connections and everything is in the right place but we arent getting any spark. has msd 6a box blaster coil, pro billit distributor. all is brand new except the msd 6a. when i tirn the msd on nothing happens. doesnt warm up or make any kind of noise is this the problem u guys think? shouldnt the msd get warm or do something when u turn the 12v on?lmk thnx
Old Dec 1, 2005 | 08:37 AM
nasdstang's Avatar
need turbo stuff,pm me
is the msd hooked up correctly? the 12v switched has to be hooked up to a 12v constant when ignition is on. you can check it with a test light. just put the test light where you have the ignition wire hooked up and turn the motor over and see if the test light stays light while cranking
a lot of times people turn the key on to find the ignition wire but they dont make sure it stays "hot" while cranking
-Ronald Reagan
Old Dec 1, 2005 | 09:39 AM
Shamus O'Toole's Avatar
Redneck Yatchclub member
also check your grounds.
Old Dec 1, 2005 | 09:44 AM
Lumberjack's Avatar
is made outa laffy taffy
90% of most electrical problems is a bad ground
All-American Street Car Performance
6187 126th ave north
Largo Fl 33773
727-667-9346
www.aastreetcars.com
Old Dec 1, 2005 | 10:57 AM
88stang5.0's Avatar
00 Yzf R1
ok i checked all the ground ran the ground wire directly to the battery and still no spark at all.
Old Dec 1, 2005 | 11:26 AM
Lumberjack's Avatar
box is fubar'd
Largo Fl 33773
727-667-9346
Old Dec 1, 2005 | 11:28 AM
sounds like it!!!! where do you live?? I could check it for you..I'm in New POrt Richey
Old Dec 1, 2005 | 11:42 AM
nasdstang's Avatar
did you use the magnetic pickup? if so, you didnt hook up the white wire did you? if not box is smoked.
a way to check the box is turn the ignition on and put a jumper between the purple and green wires, it should make a noise or arc
-Ronald Reagan
Old Dec 1, 2005 | 11:50 AM
88stang5.0's Avatar
00 Yzf R1
ok i will check with the jumper and i live in seminole. im pickin up another one as well so if its not this im screwed have no clue. thnx for the help though
Old Dec 1, 2005 | 01:27 PM
Lumberjack's Avatar
seminole? what part? im right off 102nd and seminole blv. if your nice(buy me a case of beer) i can hook mine up for ya in your car to see if yours is bad or not
Largo Fl 33773
727-667-9346
