'95 Mustang vibrating like my Harley!
Old Nov 25, 2005 | 06:23 AM
F*r*a*n*k*e*i's Avatar
Default '95 Mustang vibrating like my Harley!
Alright, so my pop's car is running like total shit. When on, the whole car shakes like an earthquake. It's like the motor's unbalanced all of a sudden. The only thing we could find wrong was a spark plug wire burnt on the manifold, so we replaced it. Still runs like shit.
Old Nov 25, 2005 | 07:10 AM
Strokd85's Avatar
Daddy-O
when idling, in gear, etc?
I am your penalty.....
Old Nov 25, 2005 | 07:22 AM
the anti-rice's Avatar
finally painted the car!
Are the u-joints any good?
-Ryan-
Old Nov 25, 2005 | 07:40 AM
Duceanahalf's Avatar
is doing your girlfriend
Originally Posted by Mars_302
sounsd like the balancer is taking a shit as usual.
+1 the rubber is probalby falling apart.
Old Nov 25, 2005 | 07:49 AM
$hawn's Avatar
lives in a glass house
yep, sure sounds like the balancer.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Nov 25, 2005 | 03:48 PM
T/S #25's Avatar
Need To Get Quicker
Did you replace the spark plug while you were at it?
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Nov 25, 2005 | 04:26 PM
chevy eater's Avatar
definatley the balancer
Old Nov 25, 2005 | 04:49 PM
Does the balancer go bad like that in those engines? I thought it was one piece. This thing vibrates so hard the body panels are moving when at idle.
I checked the timing, which should've been at the 10* BTDC, but the timing mark, if looking at the balancer from the front, is at about 8 o'clock. You can also hear the exhaust make a nice pinging sound when the throttle is hit. I'm thinking homeboy jumped a tooth on the timing chain. I think the car is close to 200 miles, never had a replacement chain or gears, so it's likely, right?
I tried to rotate the distributor back to having the 10* BTDC mark between the marker lines, but when I get close, it wants to stall.
I guess that could be due to the balancer taking a shit too, right? If that outer ring spun, it'd be impossible to time the thing. What's more likely?
Old Nov 25, 2005 | 06:05 PM
Strokd85's Avatar
Daddy-O
along with the rest, i'd go with the balancer spining. it's got a rubber "seal" between the inner and outer pieces, which has probably let go.
