ford racing cam question
Old Nov 22, 2005 | 05:04 PM
88stang5.0's Avatar
00 Yzf R1
Default ford racing cam question
OK have a 351 wtih tf twisted wedge heads and stock ford pistons with stock valve releifs. will a quadzilla cam work with this setup on 1.6 rockers w/o hitting the pistons anyone have the same setup without problems. lmk thnx
Old Nov 22, 2005 | 05:16 PM
T/S #25's Avatar
Need To Get Quicker
Not to sound like a dick or anything, but what exactly is a "quadzilla" camshaft?
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Nov 22, 2005 | 05:20 PM
nasdstang's Avatar
need turbo stuff,pm me
Z cam
-Ronald Reagan
Old Nov 22, 2005 | 05:22 PM
88stang5.0's Avatar
00 Yzf R1
lol to be honest with u i didnt know either. i know its the biggest ford racing cam made. atleast i think. so any ideas guys/galz
Old Nov 22, 2005 | 06:27 PM
nasdstang's Avatar
.552 lift
-Ronald Reagan
Old Nov 22, 2005 | 06:31 PM
T/S #25's Avatar
Need To Get Quicker
"CamZilla", I thought that's what you might be talking about.
I'm not sure if it will clear you're pistons, but I can tell you from experience that I have installed a TrickFlow Stage 2 camshaft in an 86 Mustang with a set of the Twisted Wedge heads with no clearance problems what-so-ever. As you know, the 86's didn't have any factory valve reliefs in their pistons. The following are the specs on both cams for some comparison.
TFS
Duration @ .050 int./exh._____224/232
Lift int./exh._____.542/.563
Z303
Duration @ .050 int./exh._____228/228
Lift int./exh._____.552/.552
Of course there are a few more things to think about then just cam numbers. There are variables in blocks, head gaskets, heads, etc that will determine the final outcome of P/V clearance.
Joe
FordSpeed Racing
9.78 @ 136.05
Old Nov 22, 2005 | 08:20 PM
Steve B's Avatar
brings his heater.
and now i present quadzilla
Old Nov 22, 2005 | 08:25 PM
88stang5.0's Avatar
00 Yzf R1
well thnx for the info. all check it to be safe but was just wonderin if anyone already did the checking. might be seein a little red hatch running around town watch out. lol thnx again
