Swap Question
Old Oct 30, 2005 | 01:26 PM
NeonHunter's Avatar
KillaBeezz
Default Swap Question
ive got a 93 lincoln towncar with the fuel injected sohc v-8. i'm tryin to sell it but before i do i was wondering if that motor in a fox body would be a do-able swap or if its even worth it? i just had the tranny built and im quite fond of fuel injection so i would like to use this setup if it can be done. ive done a good number of things with hondas and turbo dodges so i would say that ive got some skill and want to change it up a little. sorry if this is a dumb question but i never realy messed around with mustangs before.
Thanks Matt
Old Oct 30, 2005 | 01:36 PM
Duceanahalf's Avatar
is doing your girlfriend
yes it is possible to install that motor in a Fox body. i think you need a new K-member, one that is designed for a 4.6.
but that motor is only pushing about 195 HP. That motor has the crappy Non-NPI heads they are F1AE heads NPI heads are F5AE, that also has the all aluminum intake, it does not crack, but it is about 10 HP less than the NPI intake.
Old Oct 30, 2005 | 02:38 PM
NeonHunter's Avatar
KillaBeezz
what about the tranny? does it fit?
Old Oct 30, 2005 | 03:31 PM
it should it is the AODE which is the same dimensions as an AOD
Old Oct 30, 2005 | 04:36 PM
NeonHunter's Avatar
KillaBeezz
what fuel injected motor swap thats affordable would you suggest?
Old Oct 30, 2005 | 04:46 PM
JDL1000's Avatar
This swap can be done! You will have a world of time invested. The cost if you do everything yourself will probably be somewhere in the $2500 range for misc parts and a k-member. The motor you have is one of the lowest power 4.6's made. But think of it this way- if you do the swap for the 4.6 now it will make changing the 2V to a 4V motor later a lot easier...
Life moves pretty fast. If you don't stop and look around once in awhile, you could miss it.
-- Ferris Bueller --
Old Oct 31, 2005 | 02:21 PM
NeonHunter's Avatar
KillaBeezz
anybody? or even if its moderately priced? just want best bang for my buck and fuel injection
Old Oct 31, 2005 | 02:54 PM
if you want bang for the buck go with a 5.0. it is a lot cheaper to build power with a 5.0 than with a mod motor.
Old Oct 31, 2005 | 02:58 PM
Flastangs's Avatar
Best bang for your buck is 5.0 HO pushrod FI motor.
Old Oct 31, 2005 | 11:07 PM
JDL1000's Avatar
Agreed best bang is the 5.0 If you want to build something different and you have time and extra money go Modular. But if you do go modular don't waste your time with the 2V go right for the 4V.
