Need intake spacer
Old Oct 25, 2005 | 09:03 AM
86stang's Avatar
Default Need intake spacer
Throttle linkage is catching on my new taller rocker covers, need a spacer for a cobra intake
Let me know i need it like...right now.
Old Oct 26, 2005 | 10:31 AM
Stewart Scott's Avatar
"Now I only have two"
do you have the egr delete plate in there? If so, I used longer bolts and 5/8" nuts to bring the linkage back in line with the way it pulls the tb. Also with the taller valve covers you may have to raise the plate a bit, just drill new holes about a 1/4" to 3/16" above the stock ones. Puts the linkage ball stud mount just above the cover enough to let it the linkage snap on. I had the same problem as you with the linkage.
God bless America!
God bless our troops!
God bless the GOP!
Old Oct 26, 2005 | 11:53 AM
86stang's Avatar
Nope, no egr delete plate. Just intake mated up with throttle body.
A new spacer is what i need, i guess ill be visiting brandon ford and forkin over 80 bucks for a 1incher!
Old Oct 27, 2005 | 03:31 AM
Make sure it will clear your hood. I have a one inch spacer and it is to tall. Had to go with 1/2". Good luck..
God bless America!
God bless the GOP!
Old Oct 27, 2005 | 08:52 AM
86stang's Avatar
Trying to get a 3/8 from AEI, and put a couple of spare gaskets together and see if that gives me the proper clearance I need.
