Help Me
Old Oct 2, 2005 | 05:13 PM
evocrazy1's Avatar
Default Help Me
I Put a Spec clutch in about 1800mi... ago, Now that crap is slipping, I dont know what the max rpm for a spec clutch is but my motor makes peak power at about 7200...my shift point is 6800...I have to keep the five speed for a few more moths till i come home to put the c-4 in it...Right now i need a diaphram clutch that will withstand the power and rpms of my motor...i need help...What do u guys recommend....i'm using a spec stage 3 and a spec billet alum flywheel....
ASKED TO BE BANNED
Old Oct 2, 2005 | 05:28 PM
plazma's Avatar
Man I dont know what to tell you on this. I run a spec stage 3 and shift at about 700 and make peak power at 6500 and haven't had any issues.
How much power at you making?
I would say double check and make sure it is fully engaged. Unless your at like 500rwhp++ I just don't see you over powering the clutch.
Old Oct 2, 2005 | 09:09 PM
evocrazy1's Avatar
when i open the bottle on pump gas it goes over 500 to the ground..............
ASKED TO BE BANNED
Old Oct 3, 2005 | 10:01 AM
evocrazy1's Avatar
yes, but i have moser axles, a eaton posi and 4.10's on slicks i launch at 5200 and grap the bottle right after the 60'
ASKED TO BE BANNED
Old Oct 3, 2005 | 10:11 AM
NitroGlycerin's Avatar
World Skee-Ball Champion
How is it adjusted? This can make or break a clutch's performance.
Mike
'99 GT 35th Anniv - 13.01 @ 107.4 w/ cams & bolt-ons - Sold
'03 Audi A4 1.8TQ - :gordy:
► Home Buying & Selling Finance Tips ◄
[/b]
Old Oct 3, 2005 | 11:01 AM
evocrazy1's Avatar
i can push the pedal in about an 1 before it disengages or engages the clutch
ASKED TO BE BANNED
Old Oct 3, 2005 | 12:59 PM
$hawn's Avatar
lives in a glass house
Though I'm not a fan of Spec clutches that stage 3 should hold your h/p easily.
I'm making 450ish to the tires w/spray, launch on the 2step at 5k and my NAPA remanufactured clutch holds fine and is smooth as butter in traffic.
Would I recommend you do this, NO. I wasn't planning on nitrous when I built my car it just happened. just saying I have a LOT LESS clutch w/ no issues.
A SPEC-3 SHOULD HOLD IF INSTALLED CORRECTLY
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Oct 3, 2005 | 06:34 PM
evocrazy1's Avatar
the clutch was installed by Boosted Performance. I planned on nitrous thats why i chose a stage 3, i mean i make right over 330 hp and 360 ft. lb. tq on pump gas but i only spray on 106 or better, and with 106 the car makes about 375 hp and right over 4oo ft lb tq. I'm presently using a 150 shot in the motor....runs fine as long as i dont power shift...
ASKED TO BE BANNED
Old Oct 3, 2005 | 06:58 PM
a98ss's Avatar
we had a spec stage three clutch and smoked buy the 10th run down the 1/4 track,i havent had much luck with spec
