piston/rod upgrade
since i tore my motor apart like a retard,I wanted to upgrade my pistons,and rods.I'm prob going to boost it,so what do you guys recomend for pistons.Also i want to upgrade the rods,and also need some opinions on them.
curent short block
dss 306 pro bullit...500miles
also will i be able to sell my prolite pistons/w rods that i take out,if so how much?
curent short block
curent short block
curent short block
why just just use the prolite pistons/w rods, you no arch useing dss pistons
What's wrong with the rods that you already have?
I'm with Steve, order a new set of dished pistons if you are worried about your compression ratio, get the assembly rebalanced, and slap it back together.
As far as what your old stuff is worth, it's hard to say what you can get for it, but used parts usually sell for .50 cents on the dollar.
