Nitrous
Old Aug 18, 2005 | 05:35 PM
Jaso0on's Avatar
Is now ballin!
Default Nitrous
Ok well, I'm about to throw on my nitrous kit jus for shits and giggles to go out this weekend.. My question is this, I've always used wet kits and I've always had bigger injectors, and I've always had a MAF converted car and this time I'll be using a dry kit, with stock injectors, and a speed density car.. I'm only going to spray a 110 shot, my question is this: It's pretty much stock with full exhaust, a clutch, ported upper and lower stock intake, ported e7's, and some 3.55's, so would it be safe to spray the 110 on stock injectors, if so should I retard the timing a little bit, or will it be fine just where it is (10 degrees, stock)
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Aug 18, 2005 | 05:44 PM
SoL_93GT's Avatar
I don't think it matters whether it's mass air or not, as long as the kit works as it's supposed to increasing the fuel pressure to the injectors giving you the correct amount of fuel. You can run a 150 kit on stock injectors if you really wanted to. Just make sure you have enough fuel pump, at least a 110 lph pump or you're gonna damage something.
Briane
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Old Aug 18, 2005 | 06:02 PM
TheShow50h's Avatar
The little 5.0 that could
timing will be fine, as long as you get a kit that doesn't rely on the mass air to compensate for extra fuel, you'll be fine on 110.
-Vince
Old Aug 18, 2005 | 06:26 PM
Jaso0on's Avatar
Is now ballin!
It doesnt, it's a nitrous works kit, It was on a friends 87 mustang for awhile but he was only on a 75 shot.. Screw it, if it blows up, I've got another 302 that is BEGGING to be built and put in this thing
Old Aug 18, 2005 | 06:48 PM
WhiteHorseGT's Avatar
Love you Kev-Dawg!
dooo itttt...
RIP Kevin Slo_Si
You will be missed brother
Old Aug 18, 2005 | 06:51 PM
barry bledsoe's Avatar
The lost pony
I believe I would do the smaller jets first and do a plug reading before trying the bigger pill
Old Aug 18, 2005 | 06:58 PM
Jaso0on's Avatar
Is now ballin!
Nah, screw it.. these motors can handle 200 shots bone stock with enough fuel, so 110 should be fine
Old Aug 18, 2005 | 07:01 PM
Jaso0on's Avatar
Is now ballin!
Besides, like I said, if I blow it up I've got another 302 that I'll throw together and put in with a HUGE cam, HUGE carb, LOTS of compression, and LOTS of nitrous
Old Aug 18, 2005 | 07:27 PM
SoL_93GT's Avatar
Fuck it, go with the 200 jets.
Briane
Car Pics
Old Aug 18, 2005 | 07:32 PM
Jaso0on's Avatar
Is now ballin!
Briane
I lost them, the only jets I have are 75 and 110, I'm starting on the 110 to see how it likes the juice, if it likes it, I'm going to go get me a 150 and let it ride..
