Which differental
so i already got my gears and im thinking im going to go ahead and throw in a Eaton differental while the whole thing is tore apart just to make it that much better. prolly going to do a set of axles as weel since i will be launching from a set of sticky tires and a good suspension.
so my question is which route should i go with this? Eaton posi or is Auburn better? 28 spline or 31? which girdle should i go with: UPR($109), SHM($189+$40 for the studs), or a steeda($139)?
03 Gt - SOLD!
88 LX Coupe - 308 with a few mods...
03 Gt - SOLD!
The Eaton is better and what ever girdle is cheapest. Deffinately go with 31 spline posi and axles. I got my Ford Motorsport posi on ebay for $125 and Superior axles from Jegs for $225.
Briane
Briane
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Car Pics
so Eaton is a deffinate......
any rear end girdle better than the next? i know SHM claims there prolongs rear-end life and promotoes better cooling and will hold more oil. but also they recommend using there stud kits with them to "get the most" out of them.
prolly just go with the UPR, it has a good postion for the drain plug and looks nice as well.
03 Gt - SOLD!
03 Gt - SOLD!
i like the fact that the Eaton's are rebuildable....
i will be going with a Eaton Posi unit or a Traction lok, Moser 31 spline axles and a set of 3:73 gears to back it up.
03 Gt - SOLD!
03 Gt - SOLD!
I have seen for myself MAC rearend girdles leak after being bolted on new out of the box. T/A and SVO rearend girdles are on in the same. T/A makes them for FRPP. The newest ones from them have a "new" recessed lettering design. I prefer the look of the older s ones like mine.
Helmut
Helmut
Guest
Posts: n/a
Originally Posted by rubberneck
i have an auburn pro, its almost 10 years old.
I've heard of Auburn's crapping out in one day at the drag strip. Appearantly if you spin both tires together they'll hold up, but the minute you get one wheel spinning and one wheel not they will cook.
I personally like the Torsen style, but I'm not sure who makes one for an 8.8. My buddy had one in his 4th Gen F-body and that was a nice unit. Quiet, predictable, won't wear out, and flat out worked.
Of course if money weren't an issue I'd put an air locker in, but I think for my weekend driver V8 car I'll put a Detroit Locker or something similar in since I don't care if its loud and abrupt.
im not going with a locker, this is my daily driver for right now until i find and old beater to abuse back and forth to work. plus a locker rear-end gets on my nerves when you go around a turn and all you hear is your rear tires squealing.
03 Gt - SOLD!
03 Gt - SOLD!
