fox steering question
Old Jul 20, 2005 | 08:41 PM
cochese's Avatar
Chucking up the Dueces
Default fox steering question
i have a 92 with power steering and would like to go to manual,can i just bolt the manual rack up?or is there some modding to do?
Old Jul 21, 2005 | 05:00 AM
79 pace car's Avatar
thinks TR sucks ass now
Originally Posted by Fordified
You'll need the rack and the shaft that goes from the steering column to the rack (its longer on the manual rack so your power one won't work). If you're using a Ford manual rack, you'll also need outer tie rods from a manual steering car.
nope, all you need is the adapter( rag joint) for a manual rack, the shaft is the same. a mustang 2 manual rag joint works perfect if you can find one. my old setup was a flaming river rack w/ mustang 2 joint. worked perfect
this site sucks balls now. fuck tampa racing, not coming back.
Old Jul 21, 2005 | 07:34 AM
I'm talking about the lower shaft, that goes from the rag joint to the rack. That is longer on a manual steering car since the rack is much shorter there. That is why Flaming River sells the lower shaft.
what lower shaft? the rag joint, or coupler, connects directly to the rack. mabey i'm not understanding what your saying. i did this conversion and all thats needed is the man rag joint because the splines are different.
Old Jul 23, 2005 | 09:42 AM
HELMUT RONER's Avatar
USAFR Veteran
Question
Take a look at your power rack, you'll see a coupler right at the rack. That coupler connects a shaft to the rubber rag joint. This distance is longer on a manual rack than a power rack, hence the need for a new shaft.
Just to be sure for future reference the Flaming River part number for that shaft is FR1604 or 1604 ,correct?
Helmut
Old Jul 25, 2005 | 01:00 PM
we are talking about the same thing. the shaft does not need to be replaced, you can buy the rag joint/ coupler seperate. as i said a mustang 2 coupler /rag joint from a manual rack will work and it will connect to the shaft off the column. i did this on my car. the $180 fr shaft is not needed. fr also sells a coupler for about $60
