Hesitation..?
Been having this problem for a while now, thought I fixed it when I replaced my leaky injectors with new ones, but it started happening again a couple days ago. My fuel pump has been whining on me, so I'll be looking to replace that soon as well.
Once the fuel pump is replaced, will the hesitation go away? I have a friend of mine with an 86 SVO (2.3 turbo) that has had this issue for some time now and has not been able to figure it out.
Also, I switched to an electric fan setup and tossed my clutch fan. Ever since, my car doesn't like to stay cool at idle. I removed my fan shroud, not sure if that has anything to do with it. My water pump and thermostat are fine, fan kicks in like it should. I fire'd her up and popped the rad cap to see if any bubbles were coming out, and saw nothing.
fear is your only god
The hesitation could also be ignition related. How old is the cap and rotor on the distributor?
You definitely need a fan shroud. Without one, the fan will not cool the car at idle, like you stated.
John
John
John
1992 Mustang LX 5.0-Powerdyne BD-11A, 3.73's, FRPP clutch, chrome Ponies, Mac headers, Aeromotive regulator, MSD 6A, MSD BTM, FRPP 42# injectors, Pro-Flow Air Optimizer, Trick Flow Track Heat intake, Edelbrock 75MM TB, AFM Power Pipe
John
John
John
If the pump is loud enough to hear with the car is running, it will probably fail soon. Had that happen on a friend's car and it only took like a month before it left him on the side of the road. Also, It could be failing now and not supplying the car with enough fuel when you hit it. Hard to say, but swap a 255lph in there and see what happens....
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
