Question about spray
Old Jun 21, 2005 | 05:34 PM
Big Chris's Avatar
tampa car scene
Default Question about spray
I have a 88 5.O automatic, want to spray a 125 to 150 dry shot. What parts should I upgrade to be safe? I will definetly get a set of colder plugs and a tune, any other suggestions.
Old schooler.
Old Jun 21, 2005 | 06:09 PM
Steve B's Avatar
brings his heater.
colder plugs and take timing out, make sure your motor is in good working order. does your car have a mass air?
other than that your should be good to go
Old Jun 21, 2005 | 06:10 PM
n8secstangg's Avatar
make sure you have a good aftermarket fuel pump, we have the bbk 255 intanks for $225 installed or $125 for the pump by itself, like he said, 1 step colder plugs and take out some timing
chad
727-571-1996
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
Old Jun 21, 2005 | 06:25 PM
Flastangs's Avatar
a good MSD ignition and a window switch is my recommendation...alos remote bottle opener is neat option too.
Old Jun 22, 2005 | 04:41 AM
stangerang's Avatar
whoopdy fucking do!
basically what everyon listed was right on,
make sure the motor has no problems first, runs good, etc, especially your fuel sysetem, the injectors will see like triple duty than what they are use to, so make sure your injectors are not 50 years old or have any problems... .
then just do what was listed above, go ahead and get a pump, new fuel filter, colder plugs, tune it and take out the correct amount of timing, and probably use a window switch....
then get extras for the kit itself as you go along, like bottle warmer and purge etc etc.... running that big of a shot you should always purge before a pass to avoid a super rich condition.
200 points away from a 300
Old Jun 22, 2005 | 05:19 AM
HELMUT RONER's Avatar
USAFR Veteran
Don't forget good driving skills whenever you come across me and I spank you on motor.
Helmut
Old Jun 22, 2005 | 03:50 PM
Big Chris's Avatar
tampa car scene
No mass, old speed density. I have a little over 84,000 on my car and will be swap it to a 5 speed in november.
Old schooler.
