Rack and Pinion?
Old Jun 17, 2005 | 01:10 PM
stockstang's Avatar
The Pit Stop
Default Rack and Pinion?
Ok what I need to know is why won't a rack and pinion from a fox body mustang fit an SN95? I talked to someone who said that it could be used if you used the a bump steer kit for an SN95. Would I just be able to put my tie rod ends on the 93 rack and it work? What is the advantage of a bump steer kit, I dont really understand what it does. I'm guessing that because I would need to use a bump steer kit for a 94 and up, that its just the tie rod ends that are different and if so I am just going to buy a bare manuial rack and pinion and throw my tie rod ends on it, unless a bump steer kit is worth it and necessary.
Old Jun 17, 2005 | 01:17 PM
stockstang's Avatar
The Pit Stop
Well what im trying to do is put a rack from a 93 on my 95. So its makes sense that the 93 is to narrow. I should probably just get the bump steer kit to be safe but what does it really do?
Old Jun 17, 2005 | 02:02 PM
Rob87bird's Avatar
first off the sn95 rack should be metric thread and the fox is standard ,im not shure about width. Bump steer is the change in toe when the suspension travels in an arc. The kit allows you to be able to change the mounting point up or down on the spindle to get the least amount of change with suspension movement.
Old Jun 17, 2005 | 03:12 PM
$hawn's Avatar
lives in a glass house
Use the sn95 rack with fox inner and outer tie rods. Or use the whole sn95 setup and wack an inch off of each side of the threads where the outer bolts on.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Jun 17, 2005 | 07:15 PM
stockstang's Avatar
The Pit Stop
I'm going to be getting a 93 rack and am just seeing what I need to do to make the 93 work on an SN95.
