couple of brake conversion questions
Old Jun 9, 2005 | 07:36 PM
bubbleheadM3's Avatar
chillin the most
if your interested, I will be removing my Lincoln/SVO rear setup in the next couple of weeks. I will have everything, rotors,calipers,brackets and SVO length axles. let me know if you are interested.
Old Jun 9, 2005 | 07:49 PM
351coupe's Avatar
refinish artist
two right side Ranger axles
Old Jun 9, 2005 | 08:55 PM
herrcomestrouble's Avatar
+1 with bryan, 2 right side late 80s ranger axle ( the later years i believe were 31spline...) but dont hold me to it. You can use the master cyl from either the GT/V6 they are the same... And you do know that unless you got the ford 5lug swap for the front. You have to change spinles/A-arms to get the later year 5lug brakes to work...
-Cody
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Jun 10, 2005 | 04:37 AM
79 pace car's Avatar
thinks TR sucks ass now
mars, email me and i'll send you the info. you need the ranger axles and you swap the linc brake brackets side to side. i'm doing the same swap on my notch. or if your in springhill stop by the house. John
this site sucks balls now. fuck tampa racing, not coming back.
Old Jun 10, 2005 | 04:38 AM
here's the link
http://home.pacbell.net/black306/tech/reardisc.html
Old Jun 10, 2005 | 07:05 AM
Leonard's Avatar
OUCH!!!
aerostar axles from the opposite side work as well.
Old Jun 10, 2005 | 07:20 AM
Leonard's Avatar
OUCH!!!
Mars: http://www.ffcobra.com/cgi-bin/ultim...t/031161.html?
The axles that are needed will be either off of a Ranger, Bronco II or Aerostar van. From an '83 to '92 4 cylinder or 3.0L V6 Ranger/Bronco II with a 7.5" rear end you will need two driver's side axles. Only the driver's side will work as the pumpkin on these rear ends is offset and the axles are different lengths (you need the longer of the two axles). It should measure 29-5/32". From an Aerostar you will need two of the passenger side axles from an 86 to 97 model. The axles are all the same so they can be mix-matched (i.e. - one driver's side axle from a Ranger and one passenger side axle from an Aerostar). You can use the brake drums from either side of the above listed vehicles but make sure that they are 9" drums. The 4.0L Rangers came with an 8.8" rear end with 10" drums - these will not work.
