351w??
Old Jun 9, 2005 | 04:21 AM
bmn's Avatar
bmn
Default 351w??
Does anyone know how many horsepower the stock 351W block will hold?? In another way i am thinking in building Turbocharged 351W with forged internals and i want to get about 600 hp from the block reliably or i should buy the dart block? thanks
Old Jun 9, 2005 | 04:34 AM
Duceanahalf's Avatar
is doing your girlfriend
a stock cast 351w will hold around 12psi
Old Jun 9, 2005 | 05:20 AM
bmn's Avatar
bmn
is that even if i change the internals pistons, rods, and crank?
Old Jun 9, 2005 | 06:01 PM
351coupe's Avatar
refinish artist
You will be fine with 600rwhp and a stock block,with a turbo, good internals,and a girdle you can make alot more than 600 Ford rates them at 750hp conservativly,also the older blocks have a higher nickle content so they are considerately stronger.
