oil press problem
Old Jun 2, 2005 | 06:38 PM
Na306StAnG's Avatar
Flowmaster nut swinger
Default oil press problem
Ok i just built a 347 its a 91 block that was bored to the pistons all new cam bearing and freese plugs crank was cut 10/10 childs and allbert rings file fit. With an HV oil pump i built the motor my self i checked all the clearances everything seamed fine. started the car over a week ago i've been driving it for about 6 days did an oil change yesturday morning and drove it over to my boys shop to show him it. He asked me if he could take it for a ride he took it down 49th Street. and came back with like no oil press. Not sure if he did something or not is there something else i can do or check or just pull it back out????? I did switch out the oil press gauge same reading machine shop just laughed The motor makes no ticks or knocks at all still runs fine have not drivn it since it did that yesturday afternoon
oil Press cold
Idle 60 driving 80
Oil Press Hot
Idle 30 Driving 50
now its
Oil press cold
Idle 35 driving 45
Oil press hot
Idle none/10 Driving 30
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Jun 2, 2005 | 06:48 PM
evocrazy1's Avatar
did you replace the sender
ASKED TO BE BANNED
Old Jun 2, 2005 | 06:51 PM
Steve B's Avatar
brings his heater.
i would pull it, and take it back to the machine shop have the builder inspect everything, i would hate to see you throw a bunch of money down the toilet.
Old Jun 2, 2005 | 06:52 PM
Na306StAnG's Avatar
there's no sender it has a 2 5/8 autometer ultra light mechanical gauge but yes i did check it with another gauge same readings
Largo fl 33773
MV#72427
Old Jun 2, 2005 | 06:53 PM
Steve B's Avatar
brings his heater.
im real curious what the rod and main bearings look like, i would also replace the oil pump, do it now, while its not blown apart later and trashed.
Old Jun 2, 2005 | 06:55 PM
Na306StAnG's Avatar
I know but hoping some one chimes in with a brillant idea
Largo fl 33773
MV#72427
Old Jun 2, 2005 | 06:58 PM
Na306StAnG's Avatar
Still would like to know what made it do that there's nothing in my filter or on my drain plugs (I have a filter-mag and magnetic drain plugs)
Largo fl 33773
MV#72427
Old Jun 2, 2005 | 06:59 PM
Na306StAnG's Avatar
it could be as stupid as the oil pick up
Largo fl 33773
MV#72427
Old Jun 2, 2005 | 07:01 PM
Steve B's Avatar
brings his heater.
very possible, but no oil pressure is definately not good, i would definately pull it out, if you need a hoist, pm me you can borrow it.
Old Jun 2, 2005 | 07:04 PM
evocrazy1's Avatar
i met its a combo of the pick up and pump
ASKED TO BE BANNED
