F250 Question
My Dad has a '04 F250 SD 4 Door 4x4 Auto. He hates the auto door locks when you reach 5mph. When he gets out to get in the back seat the rear doors are locked. It drives him up the wall. I was wondering if there is a safe way to disable the auto lock function.
Thanks.
Thanks.
On my 03 Expedition there is a system monitor in the dash on the lower right corner of the guage cluster and three buttons under it on the dash. Whene I toggle through mine you can turn the auto locks off, I am not sure if it is the same on the F250 of not, though. The monitor has things like gas mileage, actual miles, trip miles, trip time, etc.
John
John
John
1992 Mustang LX 5.0-Powerdyne BD-11A, 3.73's, FRPP clutch, chrome Ponies, Mac headers, Aeromotive regulator, MSD 6A, MSD BTM, FRPP 42# injectors, Pro-Flow Air Optimizer, Trick Flow Track Heat intake, Edelbrock 75MM TB, AFM Power Pipe
John
thats funny....
Originally Posted by Fordified
From now on we'll be sure to just make shit up when you ask a question.
God bless America!
God bless our troops!
God bless the GOP!
God bless America!
God bless the GOP!
gotta love google.com
Autolock (if equipped)
This feature automatically locks all vehicle doors when the following
conditions are met:
the ignition is in the ON position,
all doors are closed,
the brake is pressed before reaching 8 km/h (5 mph) and
the vehicle is traveling more than 8 km/h (5 mph).
Relock
The autolock feature repeats when the following conditions are met:
the vehicles speed is less than 8 km/h (5 mph), and
any door is opened then closed while the ignition is in the RUN
position, and
the brake is pressed before reaching 8 km/h (5 mph), and
Deactivating/activating the autolock feature
Before following the procedure, make sure that the ignition is OFF and
all vehicle doors are closed.
You must complete steps 1-7 within 30 seconds or the procedure will
have to be repeated. If the procedure needs to be repeated, you must
wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated. Note: Pressing the power door
lock/unlock control again will toggle between activating and deactivating
the autolock feature.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
conditions are met:
Relock
position, and
wait 30 seconds.
Derp!
