302s...
Stupid question, is there a resource somewhere with all the differences between 302s? Also, anyone know if there are any differences in mustang 302s and explorer 302s?
Originally Posted by Lil Ze
Florida is the new Miami through and through.
Guest
Posts: n/a
Explorer 302's use the 94-95 style intake (with the crooked TB mounting position) but they are a Cobra style intake (higher flowing). They also have the "GT40-P" heads which are a decent upgrade over the mustang heads but may require special headers to fit in a mustang. Explorers also use a crank position sensor and coil packs rather than a distributor. Not sure what else is different.
Cast Pistons i believe
CombatFitnessBlog.com
Click ^^ to receive the controversial Ebook "Maximize Your PT" for FREE
People fear what they don't understand, hate what they can't conquer. Guess it's just the fury of man!
Who are the Hardcore lifters?? StrengthCamp RyanMagin.com
Originally Posted by craig_302
Hyperucraptic pistons is what we used to call em. I believe that someone sells headers for the gt40p's to fit other chassis. What is the motor going into, Ranger?
what year Ranger? for your application there are no differences that are going to make a difference.
if you have any questions on the swap let me know....
87 Ranger.. 302,AFR's,E303,T-5Z
88 FHP Mustang
01 P71 Crown Vic
98 Mustang GT
88 FHP Mustang
01 P71 Crown Vic
98 Mustang GT
what i was most curious about was cr, build materials, etc... looking for one of the higher output motors, because its going to be stock for a while...
ive been reading up on the ranger station's v8 swap section, and they list hundreds of parts needed for the conversion, but i figured they sounded rediculous, since some exploders comes with 5.0s.
v8ranger- i'm swapping into a 93-00, waiting to see what comes up at auction or friend's dealership as a trade in. im kinda picky and on a budget, so it'll probably take a while. looking for a extended cab shell, preferably stepside, with a/c & p/s at the least... i can always add power options inside.
-edit-
to boot, i don't know a whole lot about 302s, and i'm trying to research information on mods and the motors themselves. all i do know for sure, is i do want to run a 5 speed, f/i.
-edit-
93-97 require adapters to get the engine in...this is not a big deal, you can find them in summitt jegs etc...
98-present .... if its a torsion bar front you can use all of the explorer v8 parts including mounts and accessories...literally everything.
98-present coil spring front trucks currantly have no mounts commercailly available. you would be on your own.
302s have basically been the same since 1982...with the exception of adding a roller cam in 1985. im speaking of the bottom end,block,crank...
88 FHP Mustang
01 P71 Crown Vic
98 Mustang GT
88 FHP Mustang
01 P71 Crown Vic
98 Mustang GT
