Question on how a posi rear end works
Old May 15, 2005 | 07:26 PM
TIM TIM TIM's Avatar
could be worse
is this somthing that warrenty should cover? I got about 100 miles left on it so ill rush it in if It will be coverd. The mechanic across the street said that my car has a limited slip and not a posi rear end and told me that both tires only are supposed to spin during launching? So is whats happening normal as he says, or not? The damn guy makes everything so complicated, my parents always want to listen to him so I have to convince them that he is wrong about EVERYTHING
aim:because tim said
Old May 15, 2005 | 08:23 PM
HELMUT RONER's Avatar
USAFR Veteran
Ford 8.8 are known as trac-lock rearends, not pussy........I mean posi rearends. Limited slip is the proper term for either one.
Helmut
Old May 16, 2005 | 02:31 AM
could be worse
well ford should be free as long as its coverd under warrenty. I might just drive it untill I get gears and fix it when the rear end is already apart. There was also somthing said about ajdusting the clutches, how hard is that?
Old May 16, 2005 | 08:32 AM
could be worse
damn POS. I have had more problems with this 2002 then I did with my older 99 with 60k miles on it
