Vibration at 4000rpm's???
We think the motor is toast in my cousins coupe.In a nutshell,very bad vibration only at 4000rpmsand up,other than that very smooth,thought it was a clutch problem,put a Spec stage 3 in with new pressure plate and a billet steel flywheel,not the clutch.Also the tranny (TKO) bearing retainer was broke,fixed it also.Still the same vibration at 4000rpm.He also checked the balancer and no signs of spinning,and it's in the same place as installed 2 months ago.And ran the motor without the belts on,same.It does it weather the clutch is in or out so it's not coming from the clutch back.We gonna put a different ballancer on it tonight just for piece of mind before we tear the motor apart.Were starting to think it might be a rod possibly the crank.Any idea's.The motor only has about 600 miles on it.
Thanks
Thanks
Sorry to hear it Bryan.... Let us know what you find out...
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
is there a miss along with the vibration?... like its running on 7cyls?... Thats very close to what my car was doing. Did you check the plugs yet?... how about compression test?... Did u get the clutch in a go driving and it started? Or is that the reason you put the clutch in to begin with?...
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
The car didn't do it till the night we raced Ray,on the way home we felt it and thought it was the clutch,well the new one's in and the vibration is still there.Compression is fine and no missing,I think it's a bent rod or a broke crank.The funny thing is no vibration and the car runs smooth as hell till 4000rpm,then it shakes real bad,almost like a spun balancer.
