New Motor!
Old Apr 24, 2005 | 03:52 PM
evocrazy1's Avatar
Exclamation New Motor!
How much power do you guys thing this will make?
331 eagle strocker in a 302 mexican block
9.0 flat top pistons ( large eyebrows for oversized valves)
Edelbrock RPMs 2.02 intake
Edelbrock RPM II intake
Edelbrock 70mm Throttle body
Edelbrock 190 lph pump
FMS 30 lb inj
C & L 80mm mass air
Ford F-cam
Comp Pro magnum 1.7's
and later a 175 WET shot
ASKED TO BE BANNED
Old Apr 24, 2005 | 03:54 PM
ODB's Avatar
ODB
S.Y.L.O.
350....plus for nitrous
Old Apr 24, 2005 | 04:58 PM
Steve B's Avatar
brings his heater.
FMS 30 lb inj
C & L 80mm mass air
Ford F-cam
400 ft/lbs before squeeze
Old Apr 25, 2005 | 02:58 AM
racingtheburg's Avatar
Pro 5oh
I am with rubber head on this one wait till you see the tq numbers from nitrous
Old Apr 25, 2005 | 05:10 AM
evocrazy1's Avatar
hey guys, there's been a change in the set up of the motor now it's a 306 instead of a 331 and 11.5:1 compression ratio, and i'll be using a N-91 from AFM, so it will all be done in about a month, but i got the short block, hopefully i'll have it all put together, but when track time comes it will be a 2 stage shot, 75 then a 175 shot, so i'll hopefully be able to run some 11's on the bottle on street
ASKED TO BE BANNED
Old Apr 25, 2005 | 05:13 AM
Steve B's Avatar
brings his heater.
race fuel sure will be expensive on the street, thats an awful lot of compression for pump gas.
Old Apr 25, 2005 | 08:58 AM
evocrazy1's Avatar
with a good tune there shouldn't be a problem, because we have 11.5 comp in are truck and we use 93 it runs fine, i'll probably be using a carb so i can tune it by changing accelerator cams, jets, and squiters. But i'll se what happens
ASKED TO BE BANNED
Old Apr 25, 2005 | 09:03 AM
evocrazy1's Avatar
but if i keep fuel injection, i'll probably buy a pms or something, but i'll cross that bridge when i get there
ASKED TO BE BANNED
Old Apr 25, 2005 | 11:38 AM
Steve B's Avatar
brings his heater.
good luck
Old Apr 25, 2005 | 12:56 PM
Pro 5oh
11.5 is pushing it realllly hard matters on your timing tho....Guess if you arent pushing it to hard you will be ok
