Knocking!?!?!
Old Apr 18, 2005 | 07:28 PM
stockstang's Avatar
The Pit Stop
Default Knocking!?!?!
Ok so my car is knocking. It happened right after I made a hard run down the road and then pulled in my driveway and it was knockin. It doesnt sound like its inside inside the motor but possibly the water pump? Would that make a knockin sound? If not what accesories on the motor might knock if they were fubared? I checked the harmonic balancer and it seems intact. Goin to investigate further tommorow but just wanna see what you all think it might be.
Old Apr 19, 2005 | 12:47 AM
pita347's Avatar
all stock
Bassace just had the same thing happen to his 93 coupe 5.0 and it turned out to be the harmonic balancer which we thought was intact. P.M. him for more details if you want he went to race related yesterday and they took care of it.
Old Apr 19, 2005 | 01:12 AM
Skittle's Avatar
You Can't Moderate Me.
Look what you done did
R.I.P Pablo "Fathead" Garcia & Kevin "Slo_Si" Gonzalez Forever in our hearts.
Old Apr 19, 2005 | 08:29 PM
HELMUT RONER's Avatar
USAFR Veteran
If it's not overheating or leaking coolant somewhere then it's not the water pump. How exactly was the balancer "checked?" Did you look at it while the motor was running? Just staring at it while it's inanimate in the car won't tell you anything. If it's wobbling as it idles then it's time for it to go. Take the belt off to double check there is no serious play in the water pump's shaft.
Helmut
Old Apr 19, 2005 | 09:14 PM
stockstang's Avatar
The Pit Stop
yeah it was just the harmonic balancer. I have one off an old motor so it'll be fixed easily.
toolow
The TRuck Forum
6
Apr 1, 2005 02:28 PM
F*r*a*n*k*e*i
Feb 21, 2005 09:47 AM
riddlemr2
May 10, 2004 09:42 AM
J-Dizzle
Nissan/Infiniti Tech
6
Mar 16, 2004 06:24 PM
