WTB Solid Axle
I've got one with the following:
33 spline axles
spool
3.90 gear
TA cover..
We can work something out if you'd be interested (I realize you don't need the spool,b ut I'd be willing to get rid of it cheap with the gear and cover if you like.
33 spline axles
spool
3.90 gear
TA cover..
I am your penalty.....
the 99 and up rear ends is the correct width for your car, the older rears will work but you would need 3/4" spacers or more depending on what year you get to keep the same width you have now unless you plan on running some kind of deep dish custom wheel to make up for it
in memory of Kevin Gonzalez 6/21/86 - 9/13/06
