Sub Frame Connectors
Old Apr 11, 2005 | 05:57 AM
Mud Duck1986's Avatar
MuDuck Racing Inc.
Default Sub Frame Connectors
I finally got my sub frame connectors on. They are home made but they are soo much more stronger than any pair you can buy. Only problem we put them on with the top down and now my top doesn't line up. We had to fight with it to clamp it back down. That and does anyone know what I can use for my conv. top to take out all the mildew and brighten it up a bit? I've tried canvas cleaner but didn't work.
Old Apr 11, 2005 | 07:43 AM
Flastangs's Avatar
What about Wesley's Bleach white?? that stuff works wonders on white walls...tennis shoes..ect
Old Apr 11, 2005 | 12:24 PM
figment's Avatar
Jonathon
did you weld the subframes in when the car was on jack stands?
SOME PEOPLE ARE ALIVE SIMPLY BECAUSE IT IS ILLEGAL TO KILL THEM
Old Apr 11, 2005 | 02:02 PM
MuDuck Racing Inc.
Haven't tried that but will give it a try. Where can you find it?
We welded them on. Yeah they're not going anywhere, I was hanging from them when we had it on the lift.
Old Apr 11, 2005 | 02:13 PM
Leonard's Avatar
OUCH!!!
That's why it's always advised to use a drive on lift when installing jack stands. The chassis is stressed differently when the weight is on the wheels than it is when the weight is on the lift points that you randomly select when jacking it up.
Old Apr 11, 2005 | 05:52 PM
MuDuck Racing Inc.
Yeah it handles soo much better now. I can turn it sides soo much easier too. Big difference though. Next I'm putting in caster camber plates this weekend.
Old Apr 11, 2005 | 07:01 PM
figment's Avatar
Jonathon
the only problem is you welded twist into your vert. you have to use a drive on lift or ramps when putting subframes on a vert.
i did mine a couple of weeeks ago in my coupe and it made a big diffrence.
rviray
Mar 1, 2005 11:52 AM
rviray
Mar 1, 2005 07:56 AM
lt1boyd
Jun 1, 2004 06:22 PM
EatXhst
Feb 27, 2004 06:44 AM
