Chatter from engine bay.
Old Apr 10, 2005 | 12:27 PM
LaserCobra's Avatar
I need a helmet.
Default Chatter from engine bay.
The video camera picked-up too much noise so I'm not sure this video will help with my question.
Sometimes when I crank the car, I hear a rhythmic squeak. It sounded as thought I was coming from the alternator. My 98 did it too and a shot of WD-40 fixed it right up.
Today I installed my wideband O2 so I wanted to test it out. I nailed it in second from a low RPM and let it carry up until the car hit around 6,500 or 12.5:1 on the new gauge. I let out and came home.
I pulled into the garage and I have this chatter noise coming from the car. It seems to be coming from the alternator. I say that because the noise is focused right above it. A little to the left or right and it fades.
Thoughts?
Video
SOLD 6-17-06
'01 Silver Cobra #2709
Procharger P1SC w/10# pulley, 3 core IC, Bassani OR X, Steeda catback, 42# injectors, Lightning 80mm MAF, Tri-Ax, Fat Knob, Battery in da' trunk, JMS Tune 432rwhp / 390rwtq 12.54 @ 115 on street radials
SOLD 6-13-03
'98 Laser Red Cobra #634 of 5174
UPR Power Pipe, BBK off-road H, Flowmasters, 4.10 gears, battery relocated to da' trunk, rear seat delete, Cobra R 17x9 rims with Nitto 315's out back, shaved door locks, 13.35 @105
Old Apr 10, 2005 | 01:41 PM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
thats an easy one. my 3g 130 did that after I put a new tensioner on. The 3g's have fans on the inside of the housing, is sounds like the fans on the inside are hitting the alternator housing. when I pulled mine off there was "play" in the shaft like a bearing broke or something. I just got a new one and then no issues. id try that.
Derp!
Old Apr 10, 2005 | 01:49 PM
LaserCobra's Avatar
I need a helmet.
Could there be too much tension causing the alternator to do this?
I know of issues with the idler pulley on the 4.6 platform but the alternator going out in this way is new to me.
Could I rebuild it or should I get a new unit?
Can I still drive on it?
SOLD 6-17-06
SOLD 6-13-03
Old Apr 10, 2005 | 04:54 PM
69Boss521's Avatar
I drove on mine for a few days but it just got louder the longer I let it go. This is just a suggestion what your problem could be. I'd say get a new one...
Derp!
Old Apr 10, 2005 | 05:18 PM
LaserCobra's Avatar
I need a helmet.
Some are suggesting a tensioner or idler pulley. The noise goes away when it gets warm. Did yours?
SOLD 6-17-06
SOLD 6-13-03
joshy
Jul 20, 2006 11:16 AM
tuckinall4s
Feb 28, 2005 07:26 PM
Cronic
Feb 21, 2005 10:04 AM
Cronic
Sep 12, 2003 05:24 AM
