Carburetors SUCK! (1049 rwhp with 306 ci)
Old Mar 20, 2005 | 04:50 AM
racingtheburg's Avatar
Pro 5oh
*Speachless just wow* More info about the motor ? pistons crank rods? rings? heads?
Old Mar 20, 2005 | 05:01 PM
Strokd85's Avatar
Daddy-O
pussy.....
I am your penalty.....
Old Mar 20, 2005 | 05:25 PM
dnstommy's Avatar
Call me Chris :)
Scott yolu can run your car lean for more then a split second and not melt anything. Most care blow up their stuff from 1000 feet on, and they where lean for the first 1000 feet. I ran 26 psi and went from 11:1 to 15:1 @ 6000 rpms, I then ran the car to 9000 at 15:1, whoops. I need to watch the AF a little closer. All I cooked was a head gasket that was already going. Run the boost my brother. I am going for 34 psi this time. These carb guys keep setting the bar higher and higher. Fuckers!
On a side note, I can't find anyone who makes a AF / EGT sensor that will light up a shift light when it hits a certain number. If we have any engineers who know about this stuff (I know that a EGT sensor is just a resistor and a EGT guage is just an ohm meter) pm me im you would like to help.
Old Mar 20, 2005 | 05:55 PM
SoL_93GT's Avatar
Originally Posted by Strokd85
pussy.....
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Old Mar 20, 2005 | 05:56 PM
SoL_93GT's Avatar
Thats a really good idea, I'm surprised no one has something that does that.
Briane
Car Pics
Old Mar 20, 2005 | 06:04 PM
  #17 (permalink)
dnstommy's Avatar
Call me Chris :)
I figure that if I can make a switch that will fire when the resistance reaches a certain level. When you see the light - your on fire.
