turbo kit progress
Old Feb 17, 2005 | 05:08 PM
TIM TIM TIM's Avatar
could be worse
god i love that kit
aim:because tim said
Old Feb 17, 2005 | 05:38 PM
LaserCobra's Avatar
I need a helmet.
DAMNIT!
Now I have to change my shorts-- again.
Old Feb 17, 2005 | 05:45 PM
jdk's Avatar
jdk
Non ducor, duco
How about this..
twin 50's, 22 PSI, 12 degrees of timing.. Stock motor with just a KB BAP and 60 lb/hr injectors:
Same car, street tune, 15 PSI, 15 degrees timing:
thread at modularfords
Old Feb 18, 2005 | 04:36 AM
LaserCobra's Avatar
I need a helmet.
Old Feb 18, 2005 | 05:39 AM
Stangonline's Avatar
How is the drivability on these cars with that setup? Surging, low rpm bucking, anything?
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Old Feb 18, 2005 | 05:52 AM
BLUE2KSS's Avatar
Mechanical Engineer
on that dyno sheet, right above it, it claimed stock motor?
how would a stock motor handle 800 some odd hp at 22 psi and not split down the cylinder walls or something else catastropic like that, lol ?????????????????
Old Feb 18, 2005 | 07:56 AM
  #17 (permalink)
LaserCobra's Avatar
I need a helmet.
Ford finally built a real motor. Forged bottom, iron block, dual fuel pumps, larger injectors, etc.
SOLD 6-17-06
'01 Silver Cobra #2709
Procharger P1SC w/10# pulley, 3 core IC, Bassani OR X, Steeda catback, 42# injectors, Lightning 80mm MAF, Tri-Ax, Fat Knob, Battery in da' trunk, JMS Tune 432rwhp / 390rwtq 12.54 @ 115 on street radials
SOLD 6-13-03
'98 Laser Red Cobra #634 of 5174
UPR Power Pipe, BBK off-road H, Flowmasters, 4.10 gears, battery relocated to da' trunk, rear seat delete, Cobra R 17x9 rims with Nitto 315's out back, shaved door locks, 13.35 @105
Old Feb 18, 2005 | 03:30 PM
  #18 (permalink)
jdk's Avatar
jdk
Non ducor, duco
These cars are as driveable as they were stock.. The only difference is that the power comes on a bit later than with the eaton but stays until redline unlike the eaton..
If anything I'd say they're more driveable than stock with a good tune.. The stock ford tune leaves a bit to be desired as far as driveability.
To the person who asked how they can handle power.. These Cobra engines have made 990 HP on the stock engine, no mods whatsoever. I would not push that for long without new pistons and rods, but other than that they seem completely content making huge power with the right tune.
Old Feb 19, 2005 | 02:13 PM
  #19 (permalink)
jdk's Avatar
jdk
Non ducor, duco
Pic of the headers and turbine housings:
Old Feb 19, 2005 | 03:02 PM
  #20 (permalink)
LaserCobra's Avatar
I need a helmet.
Maybe it has been a while since I looked real hard at the engine bay but those jokers shoot straight out. Are they going to fit? Dumb question really but it makes it look like there's tons of room to work with and we know there's not.
