Will someone pleeeez help me!?? My stang wont start!
Old Feb 16, 2005 | 11:58 AM
Triple_8's Avatar
-Happy!
Question Will someone pleeeez help me!?? My stang wont start!
When you turn it over to start it doesn't do anything, We've put in a new battery and replaced the selenoid. It doesn't even make a sound like it wants to start! Pleeez help!
i ♥
Old Feb 16, 2005 | 12:40 PM
Triple_8's Avatar
-Happy!
We replaced it. And still doesn't work. We were thinking maybe the starter? But if its not that then what could it be? Do you know how much a starter would be?
i ♥
Old Feb 16, 2005 | 12:57 PM
BigDawg's Avatar
has his prioritys ef'd up
Is it turning over at all? If it is then maybe the fuel pump crapped out on you.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Feb 16, 2005 | 01:27 PM
Drewpw4ng's Avatar
stock :-\
starters are like 35 from advanced if i remember right.
Old Feb 16, 2005 | 01:48 PM
tony122's Avatar
I had the same thing hapen to me,only when i tried to start it the power would cut off like something was sucking the juice out of the battery,so i got under the ca rn hit the starter a few times with a hammer not too har dnbow,n it turned on i drove it hom en changed it out,so try hiting it,or u can take it out n take it to a auto parts they can test it out for ya as well,my started just locked out of no where not even with early warnings of it wearing out so try it out,i think it cost me like 75 buck with evrything in autozone with exchange of the old one,good luck
Old Feb 16, 2005 | 02:13 PM
Triple_8's Avatar
-Happy!
when you turn it to start it makes a few clicking sounds and then stops. We got under there and hit it a few times and nothing it still wont start.
i ♥
Old Feb 16, 2005 | 02:35 PM
the anti-rice's Avatar
finally painted the car!
Did you check all the fuses and make sure none of them are bad?
-Ryan-
Old Feb 16, 2005 | 02:48 PM
Triple_8's Avatar
-Happy!
Yes I've checked the fuses. Hopefully tomorrow my dad will get the starter off so we can try a new one. HOPEFULLY! Anti-rice are you a firefighter?
i ♥
Old Feb 16, 2005 | 02:50 PM
tony122's Avatar
well you can always take it out n take it ot the auto part sn have them test it hiting usually if they have some life left they will turn but if not they wont,also try cleaning the conections n check fuses,i dought it might be a fuse thugh,but anyways i check the solenoid next ot the battery this black round platic solenoid their one cable from the battery conects thei rn a fe wother n the othe rone a single one goes to the starter , in the middle of those 2 their is a single wire that conects to this skinny thread rod their is pretty small usually is red check if thats disconected,well anyways if u done that already just take the starter out clean the conections or just take i tn have it tested i uggest that let me know
