need a lil help...
OK i have built a couple of 302s and had no problems. I have a stock bottem end 302 in my 95 cobra. With trickflow track heat Aluminum heads. In the past I have torqued the heads in sequence 50-75-90 ftlbs.. with no problems. Well I finally got all my parts back last week, attempted to install the passanger side head. Had all the bolts to 50ft lbs. I had 5 of them to 75ftlbs.. and the 6th ( 2nd from back on the bottem) the block stripped out!! so i stoped and took the head back off. Knowing i cant Heli-coil the block while its in the car. I attempted to do the driver side head. First 50ftlbs.. no problem. Then all the bolts at 75ftlbs. Again no problem. But the second bolt ( Middle on bottom) AGAIN damn block stripped out.
I have ARP head bolts. They have perfect threads... except for the fact that the two that didnt torque have the thread from the block on them
What the hell am i doing wrong?... any suggestions?...
Thanks,
Cody
Thanks,
Cody
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
the ones that are "ratchet-style" that you twist at the bottom to set the torque are notorious for being wrong man. When they go out, they don't "pop" when they are supposed too. I had one go out on me, was set to 60ftlbs and was popping at 80-something.
did you use any kind of lube on the bolts like they recommend?
i stripped one of the 5/16 oil pan bolts in the timing cover the other day but luckilly a longer bolt fixed that
-Ronald Reagan
-Ronald Reagan
From what I understand.... If a torque wrench is dropped, or sees excessive vibration, it will throw off the calibrations of it. So if it's been in your tool box and it's been slung around a while - it could be useless now. Also, if it'd been throw down in between uses, or dropped even. I know my dad got a nice one, and it came with a padded case, to keep it from seeing the vibrations!
Sorry to hear about the misfortune Cod-ster. Hope all goes well, and you're able to get it back up to par man. Miss seeing that lil lady out and about!
Josh
Josh
well its a pretty new click type... its snap-on... I hardly use it because its only 1/2" drive. I work on 18wheelers all day.. and I have a 1" drive tq wrench that gets way more abuse than my lil ol 1/2" one. It doesnt feel like over torquing... although im used to 350ft lbs.. not 90... looks like im going to have to pull the block.. heli-coil it.. and try again. If that fails. Looks like i will be going to my 347 shortblock sooner than i thought...
