I guess 5 lug is the new bandwagon?
Guest
Posts: n/a
Dave did it a few months ago, then Brett, now Pat, and im joining in now too.
Got a fucking sweet deal from Rufflefeathers in Ocala on this setup.
Now correct if im wrong, I can use my fox body lines with sn95 calipers as long as I use my bango bolt?
Any brake upgrade on a Foxbody is a good one. I just can't stand when a person uses "you have a bigger wheel selection if you go five lug" as his or her reasoning to do it. Makes them sound like they're going to have a different set of wheels on the car for everyday of the week or something. If you got all those parts for cheap then yea it's a great deal. I had to pass up a chance to get rear discs for mine back in 2002 when I had an issue arise preventing my car from starting. I could have gotten rear calipers and e-brake cable for $30. Then the car was crushed. Pissed me off so bad.
Helmut
Helmut
I put sn95 spindles on my 86,and the tires camber out bad,I brought the camber in on the caster camber plates all the way,but the tires are still leaning out at top,do i need to run the sn95 lower control arms?
i just did the swap on my 85 vert,you dont have to change lower control arms.your stock ones are fine just get some aftermarket castercambers and it will be fine,i used 98 v-6 spindles with 03 cobra front brakes and my wheels fit great in the wheel well,as far as the back goes i used lincoln rear set up and had my friend weld the caliper braket in the stock location for a mustang track width.i used the rear stock mustang lines and flared them to fit in the lincoln hard lines
Originally posted by Strokd85
i'll stick with 4 lug thanks..
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Ryan
LOL.. shhhhhh
Honestly if I hadn't already bought a set of wheels I would've went to 5 lugs.
The 5/8" studs should help some though.
Mars, nice find man. Good luck with it.
A98ss, nice looking car.
I am your penalty.....
