anyone want a real nice "efi junk" regulator....
brings his heater.
on
i thought i ordered this
__________________________________________________ _
they shipped me this instead
A1000 Injected Bypass Regulator, P/N 13101
For 1000 HP applications that require flexibility.
Intended for use with custom fuel rails, this true billet regulator was designed specifically for use with our A1000 Fuel Pump.
Base pressure (vacuum/boost disconnected) adjustable from 30 to 70 PSI.
Two -10 AN inlet ports, one -6 AN return port and 1/8" NPT gauge port
Beautifully finished with type II bright dip red and black anodized coatings.
Alcohol compatible.
Fuel Pressure will rise on a 1:1 ratio when referencing boost.
Fittings Sold Separately
__________________________________________________ __
i need a 3/8 npt carb regulator with 3 outlets, one inlet, a return, a pressure port 1/8th inch, and a boost reference port (for future use)
for sale or trade for right regulator
Alcohol compatible.
